Just need to power it up but the leads don't match! Walkera
Discussion in 'Phantom 2 Vision Help' started by LoveDon, Dec 31, 2014.
  1. LoveDon
    Last bit !
    I have successfully attached the pitch to the bottom of the f2 naza board.
    I have a vision 2 phantom. I bought a walkera g2d gimbal. The power lead on the phantom is for the zenmuse , see pic. The power connector looked nothing like the zenmuse one on my walkera , see pic. Is there a converter cable that connects these two leads, if not where else can I plug the red lead to get power I to my gimbal?
    Can anyone help ? This is the last hurdle then it's finally ready to go !
  2. Tallyrver
    Tallahassee Fl.
    Re: Just need to power it up but the leads don't match! Walk
    I'm not sure if there is an adapter for hooking up to your cables. On my FC40 I used the power wires poking out one of the landing legs. I installed a mini toggle switch on the gimbal. The gimbal gets upset if you move it around too much,so the last thing I do before takeoff is flip the switch.i only used a single wire to the pitch pin from the Naza to the Gimbal controller.
  3. LoveDon
    Yes I have used a single wire to connect the pitch , it just needs powering and the new phantom has a totally different connection , I really don't know what to do apart from solder it
  4. LoveDon
    Can I not connect the 2 pin power lead of the gimbal to something else inside the vision 2?
  5. J.James
    Upstate NY
    You would have to solder the ends of that power plug to the battery leads on the board inside the shell. But then you dont have a way to disconnect it if you need to. So the best way to do it is to get a corresponding JST plug and solder that to the power leads on the main board in side and run the leads form the plug down one of the holes in the landing gear and plug in to it there.
  6. CarlJ
    Peru, Indiana
    Listen to James...
  7. landwomble
    I've a few things to wire up inside my phantom like headlight, gimbal etc
    What I'd like to do is solder in a small jst board so I have a few positive and negative connector pins that I could connect to. I know i could hardwire (I can solder) but a set of positive and negative connectors inside the bird seems to make sense. What am I looking for on eBay to make this happen?
Similar Threads - need power leads Forum Date
P4k no power to camera please someone tell me what needs replaced Standard/4k Discussion Jan 12, 2017
Does anyone use powerdirector/photodirector? I need the Lens Correction Profile for the p4p Phantom 4 Pro Help Dec 10, 2016
How many amps/current are needed to power the sunhans 2w and 4w boosters? General Discussion Nov 28, 2016
Need advice on powering on my P3P Pro/Adv Discussion Sep 29, 2016
What car power inverter do I need for my Phantom 4? General Discussion Aug 13, 2016
