I am about to "pull the trigger" on Litchi because of some really promising features, BUT very confused about something in Litchi's website/basic instructions....
The installation procedure seems to indicate two things that cause a LOT of hesitation:
1) The instruction pretty much states that you must remove DJIGo from your device before installing Litchi;
2) Litchi's information indicates the App will communicate with DJI Servers when installing the new App.
Are the above statements accurate? These are a BIG concern so I wanted to ask current Litchi users if I understand the above correctly.
Regarding the dump of the DJI GO App, well, I do not want to do that; it works fine, and is NOT the current version (my version is no longer available, if I want to re-install it).
Regarding communication between my device and DJI Servers, I DO NOT want DJI to detect my older firmwares and freeze things up until I update. My reasons are simple for that: What I have works flawlessly as-is, and I don't want to screw things up (or, in fact have added restricted airspaces contained in the program - I won't even go there - let's just say I believe airspace authorizations are MY responsibility, not DJI's).
Here is what I currently have:
Phantom P3 Advanced;
Firmware on Aircraft = 1.4.10 (I think this was the version that introduced POI, follow, 2K video, etc);
Remote Controller (according to GO App info screen) = 1.3.20;
Battery had the "cold temperature (?)" update with 1.4.10 aircraft update;
Device is Samsung Galaxy Tab Pro 8.8 Inch (Android)
Anyway, is 1) and 2) above correct, and are my suspicions that DJI will insist on AC firmware update correct as well? If so, I will just stick to what I have.
Forgive me if this info appears elsewhere - I really took a long time to research any answers before posting.
