  1. Stardog Champion
    Like most P4 owners range is important. ITELiTE DBS antenna have results evidentially. From what I understand this antenna is only for the 2.4Ghz command signals between ground and bird. I'm curious from the Long distance operators....are you getting video feed the entire trip out and back? Or are these videos recorded on SD ?
    One install video has you salvaging the 5.8Ghz dipole out of the stock vertical antenna and hot glue it on the inside of the casing. Any thoughts. Peace.
  2. flpholt
    palm harbor florida
    you get video feed also
  3. RocketBrew
    Arizona
    I believe the 5.8 would be in the Inspire version of the Remote Controller.
    The P3A and P3P use 2.4 for both telemetry and video.
