Phantom2, immersion 600mw & FatShark mushroom ant., H3-3D with Gopro4 Black, miniOSD, NDJ6 controller & stock antenna, DJI 5400mAh battery.
Stripped the body for painting and added a ground wire to the GPS sheilding. Everything checked out, calibrated the compass. Armed the AC in GPS and got 8 satellites, green lights, 12.4v. Spun up the props and went to 10 feet to hover. AC wanted to drift backwards then forwards. If left alone to drift the horizontal speed would increase but hold altitude. After 3 minuted the AC finally became stable in hover. Went to 300 feet and flew a figure 8 several times then came home but did not land. Went back to 300 feet, started another lazy 8 then the AC took off heading about 10 deg relative to home at high speed, 12.1v. Switched to RTH but no response so went to Atti and full power climb. Ac went to 400' ceiling. I managed to fly it home but it was directionally unstable. Hovered over Home at 400' then decended normally until 20' when it became unstable again wanting to fly away but still responding to control input. Fast decent with medium hard landing and a sigh of releif. Nothing broken. If it hadn'd been for this forum I would have lost my drone. Thank you to all of you for the lesson "Learn and practice what to do when **** happens">
