Issues with Hero and wipeouts
I bet im not the only one, but in flights, especially when speed is picking up, the gimbal/camera wipes out, especially in pan axis, i guess its the extra 8gr that does it, so my question, would a recalibration procedure in Naza fix it?
I had this issue with a new zenmuse(I assume that's what you're using?) and shipped it back immediately. An advanced IMU calibration changed the problem, but it did not fix it. The replacement zenmuse works perfectly, it's a known problem and there is no real %100 fix.
laselvasurf said:
I had this issue with a new zenmuse(I assume that's what you're using?) and shipped it back immediately. An advanced IMU calibration changed the problem, but it did not fix it. The replacement zenmuse works perfectly, it's a known problem and there is no real %100 fix. If it's too late to return to your dealer, contact dji support and they will help you(eventually...)
cokersean20
