Is this common?
Discussion in 'Phantom 2 Vision + Help' started by Davehecht, Oct 19, 2014.
  1. Davehecht
    I've only had my P2V+ for a week and already the toggle switch on the to plight hand side of the remote is broken. When not flying, I keep it in a hard case so I'm not sure how it happened. Is this common? I bought it through B&H, will they take it back?
    Dave
  2. Monte55
    Raymore Missouri
    What is broken??
  3. Monte55
    Raymore Missouri
    I know that. What is broken. The lever....does the switch itself not work????
  4. GoodnNuff
    Washington State
    ...the switch on the top right hand side of the remote...
    No, not common. Talk to the vendor you purchased it from.
  5. Monte55
    Raymore Missouri
    Not to worry. I ask because so many use the word broken to describe most anything.
  6. Davehecht
    Yes, S1 switch. It's like it got punched in. No, it doesn't work anymore.
  7. Monte55
    Raymore Missouri
    Is it actually broken or just went inside the case?
  8. Buk
    Buk
    Iowa, United States
    On my P2 Non-Vision, the switch failed electrically. Replaced it with a switch from my P1 controller. Need to fix the P! controller yet. I've seen controllers cheap on Ebay.
  9. Davehecht
    It's pushed down inside the case...although last flight I was able to get a GPS lock, so I guess it's working. But it feel VERY loose and not right.
  10. Davehecht
    It's pushed down inside the case although on my last flight I was able to lock in the GPS so I guess it's still working. But it doesn't look right and I don't feel right flying it.
  11. Buk
    Buk
    Iowa, United States
    The controller is very easy to take apart and verify if the switch is loose from the case. Are you missing the lock nut or it maybe a locking ring on the switch? Or does it just need to be tightened?
    There is a video of the process to open the case, sorry I don't have it right at the moment. Just make sure to remove the batteries before you try anything. There is a connection that must be taken apart to split the case fully open. Let me look and I'll get back.
  12. Buk
    Buk
    Iowa, United States
    Okay here is a simple video showing how to open the case. Remember remove batteries first.
    If you have the tilt control lever on the back of your controller, just use a little tape to hold it in place before you open the case. Move it to an extreme position such as inward toward the center of the case and tape it so it doesn't move. It needs to line up when you put the case back together. A small bit of tape will hold it in place.
    http://youtu.be/YEYgd1vsgO8
    The switch fits in a "pocket" so that it doesn't rotate when in use. It fits in the hole with notches to prevent rotation. On the outside of the case is a locking collar that screws on to the shaft of the switch. If you use a small screw driver, there are two "indents" or slots on opposite sides of the switch collar. If you just put the small screwdriver into one of the slots and rotate you should be able to tighten the collar.
    Several things may have happened, but most likely the locking collar is loose. The switch is important for the compass calibration procedure, setting GPS and ATTI modes and also setting Return To Home if you have it so programmed in software.
    If under warranty, speak with your vendor before attempting anything.
Similar Threads - common Forum Date
Lost drones, how common? General Discussion Jun 5, 2017
Cracked shell more common on Pro/Adv than Standard? Pro/Adv Discussion Feb 19, 2017
common problems with the ESC on V2P ver 3 Phantom 2 Vision + Help Feb 5, 2017
P4P. Do you commonly take your drone further than your eye can see? Phantom 4 Discussion Jan 5, 2017
How common is a flyaway? Phantom 4 Discussion Oct 11, 2016
