Is there a way other than litchi to go over 500 meters or out 3000 meters.
Litchi nor any other app will allow flight higher than 500m above take off level. Topic been beat to death. You can fly out as far as the controller will remain connected.Is there a way other than litchi to go over 500 meters or out 3000 meters.
Like tcope said,, 500m is it. As for distance, contact MaxxUAS and get setup with an antenna boost kit. Then buy some P4P batteries to get an extra 2min flight time, which will extend your range.Is there a way other than litchi to go over 500 meters or out 3000 meters.
I'm pretty sure this bug was fixed a long time ago in the early P3 aircraft.It is highly not recommended but if you really want to go to 500m and the. After it tells you your at max altitude click RTH and then hold the left stick up you will be able to bypass it that way but is highly not recommended!!!!
Have tried this?It is highly not recommended but if you really want to go to 500m and the. After it tells you your at max altitude click RTH and then hold the left stick up you will be able to bypass it that way but is highly not recommended!!!!
Nope.After it tells you your at max altitude click RTH and then hold the left stick up you will be able to bypass it
