Is repairing broken prop guards possible?
Discussion in 'Phantom 1 Help' started by HenryKisor, May 25, 2014.
  1. HenryKisor
    A hostile tree ran into my Phantom 1.1.1 yesterday and broke a prop guard. Nothing else. I have of course ordered a replacement set of prop guards, but would like to know if it is possible to reglue the broken guard together. If so, what kind of cement works with that plastic?
  2. npalen
    Kansas
    I found them very difficult to repair. Tried using super glue (cyanoacrylate) but it doesn't bond well. Even tried reinforcing the glue joint with thread.
    On the flip side, you will probably have learned to fly much better by the time you get the second set installed. :)
  3. doug86
    Bi-Polar
    I had one broken in the center strut of the prop guard. I used Locktite brand "Plastics Bonder" (kind of like super glue) and it worked great.
  4. Monte55
    Raymore Missouri
    Depending on how it is broken. Got a picture?
  5. npalen
    Kansas
    That's good information to have! Thanks
  6. Great Pumpkin
    Santa Barbara County, California, USA
    I glued a little one inch long wooden dowel as a "splint" to the part of the prop guard that was broken. I used ethyl cyanoacrylate, an industrial adhesive made by The Gluesmith. It will glue almost anything together, especially plastic, but also rubber, and quickly.
  7. markn
    I used super glue to piece back together one prop guard broken in three pieces and one broken off at the central hub screwed into the end of the arm. It's working fine now?
  8. Happyflyer
    Cold, Cold, Michigan
    Has anyone tried hot melt glue? I have found it sticks to almost anything. It is what I used to mount the strobe lights on the legs of my P2V.
  9. EddieR0691
    Oklahoma
    I've used super glue to bond the pieces together, It's obviously not as strong...a hard bounce on the ground during landing can break the new joint. Especially after several reattachments after hard landings. :)
    I was thinking about filling the underside groove with hot glue to make the guards a little more resilient. I don't think the added weight will be too detrimental. The thing I would be concerned about would be temperature, cold tends to make the hardened glue brittle and less likely to withstand an impact. It would also make it harder and less effective to super glue if it did break the plastic.
  10. rebelyellNC
    White Oak, NC USA
    I've had quite a bit of experience with this, unfortunately. On three different brands of prop guards, I used Gorilla Super Glue on all and it worked great. For a good strong bond, you need to apply even pressure without moving the pieces for at least thirty seconds to one minute, then set aside in a manner where there is no stress on either part (blocking, propping up, etc.) until dry, usually I try not to touch for six to eight hours to be sure. I've done this on central and outer struts, as well as the outer curved arm and the hub, all with great success.
    Good luck and remember, trees are hungry all the time...
  11. lfoard
    I have used the new Bondic plastic glue pen that cures with unltraviolet light. The Bondic unit really works. After curing one application in seconds, I added a second layer to reinforce the repair. Has not failed.
  12. rebelyellNC
    White Oak, NC USA
    I have seen a pen like this on TV, but it was called LaserBond, I think. I guess they all use the same technology. So I was wondering how well it works when used sparingly. On the commercials, they seem to really gob on the junk and when it hardens under the UV light, it's quite unsightly. Sure they say it can be sanded and painted, but with most crazy glues, it just takes a tiny bit and there's usually no overrun if you're careful. So does a large amount of liquid need to be used to expose enough of it to the light, or will a small amount work as well? Thanks...
Similar Threads - repairing broken prop Forum Date
Help w/ repairing a broken Phantom 4 Phantom 4 Help Jan 31, 2017
Has anyone ran into this after repairing a broken gimble? Pro/Adv Discussion Jan 27, 2017
Advanced Need help repairing broken socket on OFDM receiver module Phantom 3 Help Feb 29, 2016
Repairing broken/torn ribbon cable? Phantom 2 Vision + Discussion May 16, 2014
Crashed my drone!!! Should I even bother repairing it??? Phantom 4 Discussion Jul 29, 2017
