Is it possible to shut down the motors mid flight?
Discussion in 'Pro/Adv Discussion' started by dalebb, Jun 1, 2015.
  1. dalebb
    Bakersfield, Ca.
    Is it possible to shut down power to the motors in flight?
  2. Marlin009
    West Coast of Florida
    CSC should do it.
  3. Badabing
    Yes you can:
    Motorotor, dalebb and Jacob like this.
  4. tcope
    Salt Lake City, UT
    You can... it's not the best move.
  5. Jeff48920
    Pomona, IL
    Of course, CSC, but why would you.
  6. jlo
    jlo
    FL
    Is that how your P3A got to the bottom of the lake?
  7. Apparition
    USA
    Yes, but it's preferred you're high enough to CSC back on and catch it. I've thoroughly tested this in the simulator and while flying under the magic 400' number it's hard to do. Much easier from quadruple digits.
  8. Jim239
    I have been wondering about this, at what height will the motors shut down from holding the throttle down for more than 3 seconds?
    I guess those that hand catch must have to shut the motors down this way otherwise the phantom would cartwheel out of control.
    But I guess when descending from height you don't have to do it in short bursts.
  9. Mal_PV2_Ireland
    Dublin Ireland
    If you keep the left stick fully down the phantom will just keep descending and once it knows it is no longer descending the motors will turn off after 3 seconds. That could be at ground level, hand level or if it comes down into a tree for example and gets stuck the motors will turn off after 3 secs as long as you hold down the left stick. It won't shut off mid air by fully pulling the left stick, only by the 4 stick combinations that induce a csc.
  10. Jim239
    That makes sense, I thought about this as you may take off from one height and then land at a different height, say for example on a table or roof and then you may struggle to turn off the motors and would be forced to CSC.
    I will go back to reading the manual again before my P3 arrives. There is a lot to learn.
    Thanks for the info
    James
    Mal_PV2_Ireland likes this.
  11. Mal_PV2_Ireland
    Dublin Ireland
    No prob :)
  12. dalebb
    Bakersfield, Ca.
    I think this is a software flaw were as you can shut down the motors in mid flight.
  13. Marlin009
    I haven't seen a P3 manual but it is clearly stated multiple times in the P2 manuals what the CSC will do. Clearly not a flaw as in bug. Useful in an emergency situation and not a stick combination that would be used in any normal flight maneuver. Sorry if it bit you.
  14. dalebb
    Bakersfield, Ca.
    You pulled the stick to the center, what about this, to the outside bottom?
  15. dalebb
    Bakersfield, Ca.
    I didn't do it cause I wanted to lose $1100
  16. dalebb
    Bakersfield, Ca.
    By accident.
  17. dalebb
    Bakersfield, Ca.
  18. dalebb
    Bakersfield, Ca.
  19. Jeff48920
    Pomona, IL
  20. dalebb
    Bakersfield, Ca.
    I was leading at boat at close to 60' up that was turning and I wanted to go down, yaw, and still keep flight path, so in the drink I went cause motors shut down.
Similar Threads - possible shut down Forum Date
Possible Drone Strike - investigation outcome News Sunday at 9:05 PM
Advanced Possible unknown damage to gimbal Phantom 3 Help Jul 31, 2017
Is it possible to set an altitude limit? Phantom 2 Discussion Jul 30, 2017
Possible Solution to Gimbal Yaw Adjustment- Discussion Pro/Adv Discussion Jul 21, 2017
Phantom 2 + Hero4 + FPV = possible? Phantom 2 Mods Jul 20, 2017
