Is it normal for distance reading to change?
Discussion in 'Phantom 2 Vision + Discussion' started by worldsoutro, Jan 2, 2015.
  1. worldsoutro
    When I start up the bird I notice the distance changes a few feet even though I did not move yet?
  2. robinb
  3. crash1sttime
    Manchester UK
  4. worldsoutro
  5. Meta4
    Meta4 Moderator
    Staff Member
    The distance is calculated by GPS which is only accurate to about 5-6 feet.
    Subsequent GPS positions commonly differ by 1-3 feet and this accounts for the variation you are observing.
Similar Threads - normal distance reading Forum Date
Aircraft Disconnected but Flies Normally Phantom 4 Discussion Aug 12, 2017
Will the P4 remote work with P4P normally at 5.8ghz? Phantom 4 Pro Discussion Jul 16, 2017
Normal behaviour? Pro/Adv Discussion Jul 14, 2017
Camera yaw (pan?) axis rubbing, but gimbal status "normal" Standard/4k Discussion Jul 12, 2017
Horizon Tilt During Yaw Movement Normal? Standard/4k Discussion Jul 11, 2017
