4wd said:It's interesting they show the weight as 274g including the camera.
It actually looks quite decent.
syotr said:I ordered one and just received it this weekend. There were some issues with it but I think I have it sorted out after downloading software and configuring it correctly. I have not flown it on the Phantom yet. It is taller than my Feiyu-tech gimbal and requires raising the Phantom so that it does not drag on the ground.
Build quality seems decent, the listed weight is correct. It came with no manual, diagrams , or instructions. One screw did fall out and one solder joint is not well done.
The cabling is a mess with one really long, loose, unwieldy group of wires which connect the power and control wires to the board.
I have seen some promising video from this gimbal so I am hopeful that it will work as well for me.
There is a long thread about the earlier Goodluckbuy 3-axis (silver) gimbal here:dragonash said:syotr said:I ordered one and just received it this weekend. There were some issues with it but I think I have it sorted out after downloading software and configuring it correctly. I have not flown it on the Phantom yet. It is taller than my Feiyu-tech gimbal and requires raising the Phantom so that it does not drag on the ground.
I would love some pictures of the setup process or end result. From the pictures provided, I couldnt see how it connected to the phantom.
I would also love to see a comparison video too if you could do it. Not that I'm assigning you homework lol
You also mentioned you found videos of it. Can you post some links here? I havent come across any.
syotr said:There is a long thread about the earlier Goodluckbuy 3-axis (silver) gimbal here:dragonash said:syotr said:I ordered one and just received it this weekend. There were some issues with it but I think I have it sorted out after downloading software and configuring it correctly. I have not flown it on the Phantom yet. It is taller than my Feiyu-tech gimbal and requires raising the Phantom so that it does not drag on the ground.
http://www.rcgroups.com/forums/showthread.php?t=2009013
Within that thread you will find info and video about the new black one.
Big Ben said:Lighter and cheaper: http://www.goodluckbuy.com/super-light- ... tible.html
