Hi guys,
Still having gps issues. From my previous posts, I didn't replace gps antenna cos I didn't find any cracks and I was afraid of destroying something by upgrading to a larger antenna.
Anyhow I have another idea for the cause of my problem. Could the copper shielding under the gps module be blocking satellite signals?
My problem was I was loosing gps signal while flying. I've only noticed that while flying in one direction I'm getting 9 satellites, but flying in the opposite direction I'm only getting 5 and loosing gps lock. This could be while pitching in one direction the copper could be blocking out a good 45 degree of the sky. Does this sound like it could be right?
Is it only the gps module that needs shielded or the module and antenna both?
I have noticed that the copper shielding is stuck to the bottom of the module, but is also tucked in around it. Should I loosed this up a bit?
Is there any other way to stop interference like ferrite rings, or other forms of shielding that would not block signals to gps?
Thanks again everyone,
Dee
Dee
