  1. johnnco804
    Is there any update coming that will allow ipad mini 4 to connect with Phantom 4
  2. Fitcherama
    I bought an iPad Mini 4 specifically to pair with my P4 and been utterly delighted with the relationship ever since. What is the problem you have? The two are made to be together.
  3. johnnco804
    My mini 4 will not pair. I online chatted with DJI and they said it is not capatible with the mini 4 and they didn't know when an update would be available. That didn't make sense to me.
  4. johnnco804
    It works great with iphone 5s
  5. WWK888
    That is bull ****, I have had no problems with mine and it is current with all updates.
  6. WWK888
    Try uninstall the Go app and reinstall again.
  7. PROJEFFREY11
    I use a mini 4 with my phantom 4 works great.
  8. BriRi
    I also used mini 4 without issue until I got the iPad Pro ... Recommend you follow WWK888's advice
  9. johnnco804
    I deleted the DJI go app and reinstalled. What am I doing wrong?
  10. ukbandit
    When you say trying to pair, you do know you should be plugging a cable between the ipad4 and the RC
    No pairing required.
  11. johnnco804
    Thanks UK, I meant all I get when connect cable to rc, where it should say "connect camera" I get "how to connect"
  12. phantom13flyer
    I bought a new mini 4 about 3 weeks ago and it has worked perfectly . Love it
  13. phantom13flyer
    Download the Dji assistant for your pc and hook up your p4 to your pc. Also sync your flight logs and uninstall and then reinstall the go app.
  14. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I believe they just mean it's not on their recommended device list.
  15. Marc Hufnagel
    Illinois
    mine works a treat. No issue at all.
  16. thomo
    I use my iPad mini no problems pairing but when flying my screen on the iPad is pixilated / and screen goes green and lags until it catches up. any suggestions?
  17. johnnco804
    The processor is too slow
    Stealthmatt likes this.
  18. Derek Mackinnon
    Aberdeen, Scotland
    My iPad 4 mini did the same thing until I plugged it into my MacBook and erased contents and settings via iTunes, someone on here told me to do that and it eventually worked.
  19. martybabe
    ipad 4, phantom 4 working flawlessly here. I will confess, there was one time where they wouldn't connect. After several re-boots, I realised I hadn't used the connecting cable :oops: in my defence, I am used to flying the standard which doesn't use a cable. Just another senior brain fart,
  20. johnnco804
    I don't have a mac book, already erased contents and settings via ipad as I saw your post before, but still doesn't work. I will call the place I bought from and see if they have any suggestions.
Similar Threads - anyone able ipad Forum Date
Has anyone tried the vufine wearable display? Pro/Adv Discussion Jun 24, 2017
Anyone has P4 series working with tablet and Glyph ? Phantom 4 Discussion Apr 24, 2017
Anyone know if you can run Litchi on a fire tablet from Amazon? Software Feb 27, 2017
Standard Anyone know if Dragon Touch S8 Tablet works with Go App? Phantom 3 Help Feb 23, 2017
4k Hdmi module won't fit P3 4k wrong ribbon cable Does anyone else have this problem? Phantom 3 Help Dec 23, 2016
