Ipad Screen Scrolling
Tauranga, Bay of Plenty ,New Zealand
I am having problems with my ipad mini 2 Model ME276X/A during flights.
When the AC is on the ground and ready to fly the video signal to the screen is rock solid.
Once the AC is in the air the video starts to break down and freeze the screen, this makes smooth video filming difficult, and if the aircraft is kept in sight or out of sight the result is the same.
I tried un caching items and also removed all apps not required and turn off all non essentials.
It doesnt seem to matter if the AC is close by or 500m away.
So far no change.
Ive changed lightning cords and checked all connections.
I have been using this same ipad for a few years and up until now, no issues.
All icons in the DJI app stay visible and are rock solid, also captured video on the onboard mini SD card are always there as filmed and uninterrupted .
If it was the camera, and or ribbon connections I would imagine the recorded video would bu affected, but its not.
Any ideas
Regards Mike
Hi any change when you select different transmission channel,
Thks, if the SD card has good video playback , how would changing it sort the ipad screen problem?
It will hopefully give you less signal interference when streaming your video back to your device from the drone. Also dropping the transmission rate down to 4 Mbps in the HD settings will make life easier for your device.
