iPad not recognized after DBS itelite mod
Hi,
I just install the itelite DBS mod, but now my iPad seems not be recognized by the RC.
The ribbon cable seems to be correctly plugged.
What went wrong?
Thanks a lot for your help
I reopened and check every connections, all seems to be good.
Is there a way to be sure the USB/HDMI card is properly connected ?
thanks
More infos :
- RC is correctly bind (green led when the drone is on)
- I can start motors, everything works
- I remember that C1 pulled the camera down when pressed. Now it emit a "beep" but the camera doesn't move.
I think my clamp may damage the ribbon, but i'm not sure. Attached some pics.
Is there anybody here damaged the ribbon ? where can i find another one ?
DJI sells the HDMI card, is there a new ribbon in the pack ?
Did you try to loosen the clamp and insert the ribbon further into it, and the re clamp? It looked like it may have slipped out some.
Yes, I tried multiple times.
Previous pics are just to show the ribbon little damages.
Attached, the the final pic of the RC when a made tests. Ribbon connections are correctly aligned.
wkflysaphan4
