iPad Mini Vision APP no longer available
Discussion in 'Phantom 2 Vision + Discussion' started by db51, Sep 6, 2014.
  1. db51
    I tried to download the Vision APP for a new iPad mini that I bought specifically for the Phantom....the Vision APP has been removed and is not available according to a big dealer who said it was temporarily unavailable. W T F is the deal.
  2. Jeremyconk
    The App is available.... But it's made for iPhone, and needs to be 2x scaled up for ipads....
    Just look for Iphone apps, not Ipad apps.... It's there I just checked....
  3. db51
    When I go to the APP store and do a search for the APP on my iPad mini, it won't even bring up the APP period, I'm assuming it is recognizing my iPad and not allowing it. I can get it on my Galaxy S3. So how do I download the APP if it won't show up on my selection screen. I was on the phone with Apple for 4 hours and they couldn't help me. Advice appreciated.
  4. brorex
    Are you pressing on the phone tab on top of the app store on the iPad?
  5. jasonb777
    Jacksonville n.c.
    On my ipad mini I couldn't find the app neither and what I did was web searched and found the DJI VISION APP and lo and behold there was a download available, go figure..
  6. tizzl10
    that is because you have to change the settings on your ipad mini to search for IPHONE apps. DJI made the app for iphones, not the mini nor the ipad.
  7. sbjr0203
    Connecticut
    No issues, just deleted on mini & went into App Store down loaded no issues, like other posts said switch to "iPhone only"
  8. wattage
    Scotland, UK
    Seriously?! They couldn't advise you to change your app store search results to 'iPhone' instead of "iPad only apps" in 4 hours?
  9. aljames
    I'm curious. DJI say the iPad mini is "not recommended". Is there a reason for that or does it work much better then the iphone?
  10. sbjr0203
    Connecticut
    Probably they wanted everyone to squint and strain eyes, In turn you lost sight/control fiery crash ,causing you to buy another one
  11. aljames
    Thanks. That's what I thought. Seems strange, after all, bigger superior screen!? No brainer.
  12. DCGOO
    Indianapolis
    It is because the APP was designed for the iPhone. No iPhone only app is ever recommended for use on the iPad, unless there is a separate version specifically for the iPad (often delivered together). It would certainly be nice if DJI created something specifically for the iPad, but so far, nothing. So we all just have to use the Phone app in 2X mode. Not great, but definitely better.
  13. Michigan_PI
    Detroit, MI
    Probably "not recommended" due to it not fitting in the phone holder. There is a holder out there that the mini fits nicely in and screws right onto the same mount the phone clip uses.
    viewtopic.php?f=27&t=18095&hilit=mini#p165212
  14. Mac_Guy
    I've had my P2V+ for about six weeks. Started with using an iPhone 5s, but my eyes just weren't good enough for that tiny screen. I had an iPad Mini, first version - non "Retina display", and decided to give it a try even though DJI didn't "recommend" it. I had the problem with the iPad's "menubar" showing Cell/WiFi/Time etc. blocking out some of the Vision App info along the top of its window when it was "expanded" full-screen. I could live with that.
    But things got worse when I started using the "Ground Station" function. The iPad Mini couldn't handle the processing load for the camera video when I went from the "Ground Station" window to the FPV camera window to observe the flight or adjust camera tilt. The video lagged way behind actual flight status, jumped badly, and just wasn't usable.
    Others on this forum have been using the iPad Mini successfully so I came to the conclusion that I needed to get the second version of the iPad Mini with the more powerful A7 processor and "Retina display."
    I went on the Apple Store and found they had "refurbished" WiFi only with 16 GB iPad Minis (Retina with A7 chip) -- which I bought. Refurbished units have the same Apple one year warranty. Also figured with Apple's 14 day return policy I'd make sure it worked with the P2V+ "ground station," or I'd return it.
    Well the iPad Mini with "Retina display" works fine. In fact, the iPad's top menubar no long interferes with the Vision app's display. There's really no need for DJI to do any additional programming to get the app to work on the iPad Mini. Haven't tried any iPad or iPad Air units, but since the current models all have the same 2048 x 1536 resolution, the display should be OK. However, the iPad with "Retina display" does have a less powerful A6X chip which might be a problem -- don't know.
    I'd definitely "recommend" the iPad Mini "Retina" for FPV and "Ground Station" flying. Small enough that the controller isn't overly bulky.
  15. Michigan_PI
    Detroit, MI
    And I thought it was just my iPad mini that lagged the video when flying GS missions... lol!!
    Works fine on my 5s though.
    I don't use the GS app at all now, although I can see good use for it, I just haven't used it since its release.
    I fly with either a 4s, a 5s or the iPad mini, which ever I feel like using at the time.
    I can see the screen much better on the mini though.
  16. db51
    Now I can't get my iPad Mini to connect to my home WiFi. lmfao. What a fricking hassle. Thanks for all the info...hopefully I can get it downloaded before I go blind squinting at the S3 or crashing.
  17. db51
    Bingo! Got the Download. thanks for all the help.
  18. SpikeFinch
    Agree! Same set up here and love it!
  19. albertrobin
    Actually i tried the DJI Vision app ver. 1.0.56 on my Ipad mini retina with ios ver. 9.2 but unable to display some of the parameters & functions...maybe because it doesn't have a GPS....
Similar Threads - iPad Mini Vision Forum Date
V3 Vision + with Ipad Mini Phantom 2 Vision + Discussion Jan 15, 2015
Can iPad Mini be used for DJI VISION App? Phantom 2 Vision + Discussion Dec 9, 2014
Solution iPad Mini Retina Attachment on DJI Vision Plus General Discussion Jun 22, 2014
Ipad mini2 with cell Classifieds Sunday at 9:37 AM
Can someone help with P3P with IPad3 mini-please? Pro/Adv Discussion Jan 13, 2018
