iOSD Mini Help
I have a phantom 1 with Zenmuse H3-3D, PMUv2 and I just picked up a iOSD mini. My question is, what do I connect the iOSD mini yellow (video-in) and brown (ground) wires to?
Since you're using the GCU with the gimbal instead of the upgrade board, you'll need to connect the video output leads from that (looks like a headphone jack) to those matching inputs on the iOSD mini.
Unfortunately those plug-in-play cables and that diagram only apply if you're using the P1 upgrade board.
Good to know, thanks
These are to two pictures i have that i took when completed. I will able to get better shots later tonight when i get back home.
I moved the cam-bus connector inside. and have the wires come through a hole near the legs. One line into mini iosd, next to board, final 2 into the immersionrc tx
Any idea where I can get a cable like that?
That's a Phantom 2? I have a Phantom 1—diffrent set up, right?
Found the cable in my Zemuse box :oops:
Correct me if I'm wrong, but, I'd plug the AV (headphone jack looking) cable into the Zenmuse and solder the yellow and black to the yellow and brown on the cable coming out of the iOSD mini?
hirehackers
