Hi all, recently got a phantom 2, installed iosd and transmitter (TS832) and all has been working. The other day I read about the gopro charging causing possible interference so let it fully charge on the phantom for about 15 mins. The transmitter got pretty hot and now I can get the IOSD info but no video? Has it fried? Very new to this but having a ball!
Well if you're getting iosd info your transmitter must be working. Must be st the Gopro end. Make sure its on and on a video recording setting. If that's all good I'd start checking your connections.
There is a possibility you have broken ribbon cable to the camera or the ribbon cable is not fully seated in the USB adapter. There nothing wrong with the cables running from the CAM socket to the iosd or TX or you wouldn't have nothing on the monitor. Next check the camera and monitor be sure they are both on either PAL or NTSC.
