installing new dampers
South Florida
Any online instructions on installing new dampers???? I was told that my white dampers should be replaced by the gray ones from zen to avoid "jello"ing I am having. I just never did this and cant find how to do it.
>> I tried the Black dampers - bad jello
>> I tried the gray dampers - bad jello
i hate this thing :)
going back to white... f this
cant even return anything... and I think the video sucks... very noisy and "flashy"
are you using "GOOD" "NEW" DJI Props? DO NOT USE after market props... They suck...
Most reputable dealers give you a 30 day window to return your Phantom. B&H, Amazon, MSRP, others. Sounds like you should sell your Plus, cut your losses and move on to something else. No sense in being un-happy!
I found if you are using FPV mode there's is definitely more bouncing around. Try shutting it off.
good balancer for these props?
i will also check to make sure not in FPV mode
I am unhappy because everyone says how great their vids are and i just dont see it
I use tweezers, gently.
wkflysaphan4
