IMU Orientation Change? Correct for GS Yaw Functionality
Discussion in 'Phantom 2 Discussion' started by cashaau, Dec 22, 2014.
  1. cashaau
    New to the forum here... All help is appreciated.
    I am interested in changing the yaw (right 90°) so when flying between waypoints in Ground Station, the GoPro on the 3D gimbal will always be pointing 90° to the flight path. As far as I have researched, GS does not have this functionality. Thus, correct me if I am wrong, if I change the software IMU orientation of the Naza M, this will trick the copter to facing right while flying. OR any help on getting Yaw 90° between waypoints will be helpful.
    Thanks - CASHAAU
  2. Mako79
    Sydney Australia
    Sounds complicated.
    This sounds dumb... but maybe try mounting the gopro 90 degrees sideways, I'm sure the dampeners line up, but you may need a longer cable for the H3-3D. You can always relocate the anti-interference board and purchase the "part 3" cables for $10.
    Try with the landing skids on. If it works and the landing skids is in the footage, remove the offending landing skid.
    Then grab a mate and help you launch and catch land with the remaining landing skid.
    It may not work because the yaw system talks to the IMU so the horizon may tilt a little.
  3. SteveMann
    Westford, MA
    Welcome to the forum.
    What you describe is often requested, basically the ability to fly 'course lock' in MP, but we're still waiting.
  4. cashaau
    Thanks everyone. This is what I figured...
Similar Threads - IMU Orientation Change Forum Date
Litchi maximum "wait for" waypoint time? Software Saturday at 3:46 PM
Maximum flight distance reached Pro/Adv Discussion Saturday at 10:05 AM
IMU Phantom 4 Pro Help Friday at 11:08 AM
P4 pro plus maximum distance more than 2 km in 5G band in Europe Phantom 4 Discussion Aug 17, 2017
Simulator Won't Run After App Update Pro/Adv Discussion Aug 12, 2017
