  1. Hugh from aus
    Hi,
    Am new to phantom drones, have purchased the phantom 4 and upgraded firmware etc. Read you need to recalibrate the IMU etc. When doing this the cal runs but the 0% does not change and after five to ten minutes it says n/a. I hear a slight clicking noise or like a moth fluttering when the drone is on since doing this or updating firmware tonight. Any suggestions?
    Thanks,
    Hugh
  2. Hugh from aus
    Got it working by switching from iPad to iPhone. When I went back to iPad gimble was disconnected so no picture! Had to reboot iPad to get dgi go to work. Still have the ticking noise though.
  3. RémyHeli
    Ticking noise is normal, ultrasonic operation
  4. uav.hans
    Hi Hugh,
    So how's your bird doing? All set up and flying already?
    If not, please check for the latest firmware of your aircraft and version of your Go App. Update everything then calibrate IMU and compass. The latest updates seem to go well with other P4 pilots.
    Best wishes.
  5. Hugh from aus
    Hi,
    Thanks for the replies. P4 all set up with latest firmware and taking it out for first flight tomorrow. If it's as easy to fly as the simulator..... All should be good.
    Cheers,
    Hugh
  6. snowghost
    SoCal, USA
    I don't know why people mess with the IMU after updates. I have never had to do IMU with any of my Phantoms. Look at the readings in the app before each flight and if it tells you to, go for it.
Similar Threads - IMU calibration working Forum Date
IMU Error/Calibration Before Every Flight Phantom 4 Discussion Aug 1, 2017
IMU Calibration Phantom 4 Discussion Jul 31, 2017
IMU Calibration Require Phantom 4 Help Jul 29, 2017
IMU Calibration Wich way is the right way? Phantom 4 Pro Discussion Jul 24, 2017
IMU calibration will not work after todays official update Phantom 4 Discussion Jul 8, 2017
