imu calibration error phantom 3 4k
Hello
I want a solution to the problem this topic
i have a problem in P3 4k
When you attempt to aviation show me a problem
Come and imu calibration error
Upon entering the sensors
No Read
Please watch the video and img
Are you running the latest firmware version?
Did you see this error the first time you used your Phantom? If not, when did it starting appearing?
Which firmware version do you see in the "General Settings" --> "About" section of DJI GO?
Hello
No Read
Hi, I'm in Chicago and just bought my P3S. When I first connected, imu error showed with a constant beeping. I tried to calibrate but it would not let me. I think you have to install, or reinstall, the firmware update. First time I tried update it failed, so I tried again and then it took. Then I turned off everything and reconnected. IMU now let me calibrate. Good luck.
Hello
how re-installation of a new system or return to the old system
shimuafeni fredrik
