Imu cali
Discussion in 'Pro/Adv Discussion' started by t2adze, Mar 10, 2016.
  1. t2adze
    I have done ImU calibration cold one somewhere in beginning of january. No warming up signs. All perfect.
    When do i need to recali rate imu? Or do i ever have to do it again?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It's recommended to re-calibrate the IMU after installing new firmware or crashing/dropping your Phantom.
  3. With The Birds
    Australia
    As i suspect a lot of others do, as part of my pre flight check i look at compass and IMU sensor values. Make sure you do this with the phantom on a solid surface. You should expect x and y values to be zero or close. Z Should be at or close to 1 with the phantom kevel given the z axis is measuring gravity.
  4. Mako79
    Sydney Australia
    Change in climate.
    If you are going from a warmer to cooler conditions, the IMU warm up times will take longer.
  5. abbottts
    Ok fellas, is there a difference between calibrating the compass in the P3A, or the ImU. I guess I'm asking is there 2 type of calibrations we should be doing?
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Yes. There are actually four different calibrations you should be doing. See step #48 here.
Similar Threads - Imu cali Forum Date
IMU Calibration ... Phantom 4 Pro Help Dec 28, 2017
IMU works but doesn't calibrate... Any ideas? Pro/Adv Discussion Dec 28, 2017
IMU Calibration fail.... HELPPPPPP Phantom 4 Help Dec 26, 2017
What is an ACC1 error when trying to calibrate the IMU Phantom 4 Help Dec 15, 2017
Calibrate IMU/ Aircraft Disconnected Problem Pro/Adv Discussion Dec 10, 2017
