ImmersionRC SpiroNet 5.8Ghz V2 Antenna Set - Worth it?
Discussion in 'FPV (First Person View)' started by Jebus, May 1, 2014.
  1. Jebus
    I've got the FatShark Predator v2 goggles and was considering getting the ImmersionRC SpiroNet 5.8Ghz V2 Antenna Set, but thought I would see if anyone knows whether it's actually worth the upgrade? With the stock antennas (and 250mW tX) I get really good range, but the video breaks up every now and then (even when flying close by) and when returning home from a long distance (probably because the antennae is behind the gimbal when the Phantom is flying back) - which I've read is pretty common.
  2. GhostMaster
    They are great antennas, worth it imo.
  3. jondrew
    I was a bit disappointed with them. If I were to do it over again I'd get something like then IB Crazy CP antennas biased on what I've read on the forums here. Maybe one of those on your phantom and a helix type on your FS. Of course you may not want to be seen in public with that setup strapped to your face.
    http://www.getfpv.com/5-8ghz-blubeam-whip-with-90-degree-sma.html
    http://www.getfpv.com/5-8ghz-9-5dbic-helical.html
    That said, I have the spironet on my P2 and one on my monitor. I also have the Immersion/FS patch antenna on the other channel. So far I've gone out to 2km with reasonable results. I could probably go further
  4. Jebus
    Yeah... I don't know if I'd want to go with the helical antenna. They look big & ugly to use for goggles. I guess the SpiroNet's only $50 - but I'm just not sure if they would make much of a difference.
  5. henrycruz
  6. QYV
    QYV
    NYC
    If you're interested in learning why, watch the first 5-6 mins of this video he very clearly demonstrates why that happens, why the stock antennas are crap, and why omnidirectionals are better.
    I personally have a set of FPVLR antennas which are like the ferrari of antennas and even just with the pinwheels I get excellent reception and no breakups, so far out to 250m or so with the Phantom in any orientation I haven't even put on the helix yet and tried for super long range.
    I don't know if THOSE exact antennas are "worth it" but I can tell you that a good, quality set of pinwheel/cloverleaf antennas can make a lot of difference.
  7. Jebus
    Thanks QYV. I ended up getting them, and they have been great. I haven't tested the crap out of them (I haven't tried a distance run), but I definitely notice a big improvement. I hardly get any video breakup anymore (although I don't think I've have it out past 600m since I've had them).
  8. henrycruz
    May I see a picture of your set up? Specially how the transmitter is attached and the orientation of the antenna. Thanks! :)
  9. Jebus
    Sorry, this is the best pic I have on my phone right now.
Similar Threads - ImmersionRC SpiroNet 8Ghz Forum Date
What Tx antenna to use with ImmersionRC 5.8GHz SpiroNET? General Discussion Oct 9, 2014
ImmersionRC SpiroNet 5.8GHz Patch Antenna FPV (First Person View) May 16, 2014
ImmersionRC 5.8GHz Circular Polarized SpiroNet V1 or V2 General Discussion Jan 26, 2014
Increasing FPC range? P2, ImmersionRC 25mw 5.8Ghz FPV (First Person View) Nov 9, 2017
Phantom 2 FPV install pics. Flysight & ImmersionRC Phantom 2 Mods Oct 31, 2015
