Image transmission quality?
Poca, WV
What Mbps should it be set on? I read if you lowered it, then you would have more consistent transmission. Where should it be set?
P3P
P3P
Did you find out the answer to this? I would like to know also. I am having trouble with green screen / black lines on both my P3P and P4. I'm trying to set the image transmission to custom but I am unsure what channel is best (default is 20) and if I should use 6Mbps. Default on mine is at 4Mbps, and I read that 10Mbps didn't work well?
wkflysaphan4
