I opened the back of the camera and removed 4 black screws from the board. Then removed the 2 silver screws holding the lens in place. Screwed off the lens cap on the front and removed rubber lens shroud. Then pushed the lens in until it came out. Then holding the metal lens base with Chanel locks unscrewed the lens counter clockwise until glue freed up. Then reinstalled in the [emoji327] and reinstalled the board and rear cover. Started the bird and adjusted the focus from the front with needle nose plyers rotating the lens until I had it focused on a chart about 4 feet away. Reinstalled the rubber shroud and lens cap. Can't believe the difference !! I have a
p4p as well and it's very close to that now. If you need any info let me know here is a link to a video I used as a reference to access the lens. In this video that are swapping the lens but the main procedure is similar
Sent from my iPad using
PhantomPilots
