I'm at my wits end
CarlJ said:
low&slow said:
I removed all the software and started over with the link you provided. I did 1-6 again with no luck. So I loaded V1.4. The gimbal started to vibrate and jump around. So I put V1.5 back on it. I can change the speed in RC Sensitivity It will let me do that, but if I change the box below that (Init Tilt Angle) when I press enter I get ?????????!.
Yeah, it's gonna twitch until we get the software/firmware issue fixed, and it will not except any input until we get the issue fixed.
We must have these 3 things:
#1) The v1.5 USB Driver
#2) The v1.5 Software (Not 1.4 or 1.3 or any other, it MUST be v1.5)
#3) The v1.5 Firmware for the control board AND the motors
(Edit: and just to be extra clear, all the above must match, it ALL has to be v1.5)
Follow the directions in this video: https://www.youtube.com/watch?v=A2WXguD2Ghs
If you are unable to complete any step in the video, please post here with that failure, and screenshots are always helpful.
To be clear the only issue I'm interested in at this point is:
A) All software/firmware updated to v1.5
B) Your ability to open the com port, and upgrade the firmware as instructed in the video, make sure to follow each step in the video.
Once that is complete I'll post directions for flashing the control board with the new tilt angle, but it simply will not work until the above is complete.
Yes I have done A and B.
Ok this should be the last few steps.
Set your default mode to "Default Mode: stick position mode" in the drop down menu in the gimbal software.
This video will explain how to write your settings to flash. You will not need to adjust your gains, just your default mode and your tilt angle.
https://www.youtube.com/watch?v=BwogodUlGAI
