- Joined
- Mar 11, 2016
- Messages
- 118
- Reaction score
- 6
Has anyone tried this app from the playstore to increase range? Does it work ok and is worth buying? Thanks
For 5 bucks, I'll give it a shot. I cannot get out more than a couple hundred feet in a wide open field with no interference before getting RC & video disconnects.
So made the changes to 27, went out got sat lock and this is how far I got.
F 01m 44s 55.4 ft 39 ft Data Loss Downlink data connection lost for 63.5 seconds
G 01m 44s 55.4 ft 39 ft Mode Mode changed to AutoLanding
H 01m 44s 55.4 ft 39 ft Warning Signal Lost. Aircraft Returning Home
I never got signal back on it - it ran the RTH and landed.
If you checked all four boxes (two are for the Telnet) then you install it, like you should. You can't check the levels afterwards if you don't install it, says so right in the readme file. And just because the sliders are at 27, doesn't mean you can't change them.I don't even know what telnet means, so have decided to leave it alone.
As far as I could tell you just select the 4 check boxes and tell it to "apply"? The sliders were both set at 27 db but when I ran the check again it said 17 db for both, so other than sliding the sliders that were already slid, what else is there to do with it?
