I see both map and video on my screen yl
Italy
Good morning and greetings to all, I have a problem viewing the app dji pilot of p3, I see both map and video on my screen you know what is the problem ??
You're supposed to see both the map and video on your screen. You can toggle back and forth by touching the mini map, or the mini feed depending.
so it should be but when I touch the window I see a small shift map and then the video never together
Assuming I understand you correctly, one of the windows will always be mini overlaid on the bigger window.
So youre saying you never see video? or you're saying that whatever is in the mini window is black? In either case, try reinstalling the app, and rebinding your controller to the quad.
I installed several times the app dji pilot I updated with latest version but from May to now I have not seen the map and video together, the edges of the window I see a small edge of 1 mm of map or video
cokersean20
