I messed up buying a Zenmuse
Discussion in 'Zenmuse H3-2D GoPro Gimbal' started by ethover, Mar 16, 2014.
  1. ethover
    Well, I did a good one.
    I have a Phantom 1 and was in the market for a Zenmuse Gimbal. Long story short, I bought a Zenmuse, but it was for the Phantom 2! It looks like I'm missing the GCU and some cabling.
    What would I need to buy, to get it to work on the Phantom 1? I have a PMU.
    Thanks in advance!
    Eric
  2. rilot
    Twyford, UK
    You would need the GCU, the cable kit and the mounting bracket.
  3. ethover
    Ok, what is the mounting bracket?
    Also, would the iOSD mini be able to plug into the GCU?
    Eric
  4. rilot
    Twyford, UK
    You plug the iOSD in to the GCU yes, with the 3.5mm cable that comes with the GoPro kit. I'm assuming you get a new one with the GCU if you buy one.
    The mounting bracket: http://www.heliguy.com/Quadcopter/DJI-P ... g-Bracket/
    I don't think the one that comes with the gimbal for the P2 will fit the P1.
  5. tupes
    New Orleans, La
    Where where you able to get the setup for the Phantom 2? The only ones I've seen are the complete package.
Similar Threads - messed buying Zenmuse Forum Date
So, I messed up not buying the extra battery for $69.00 Phantom 2 Vision + Discussion May 9, 2014
Standard new firmware 1.9.2 has messed up my phantom 3 standard. Phantom 3 Help Jul 3, 2017
map messed up Phantom 4 Pro Help Jul 2, 2017
Update Messed Up Gimbal Pro/Adv Discussion Apr 22, 2017
I messed up big time Pro/Adv Discussion Apr 11, 2017
