I Knew Zero AND Now I'm The FPV HERO!
Discussion in 'Phantom FC40 Discussion' started by Jimfreestyle, Jul 14, 2015.
  1. Jimfreestyle
    So guys I've got from knowing nothing about phantoms to a full telemetry and FPV set up on my new phantom in just over two months thanks to the help form this forum, thanks though everyone I annoyed :) with a few errors on the way I think she's come out nice! Just waiting for my new 10" screen to arrive. If anyone needs any pointers I will return the favour. Cheers Jimmy
    ImageUploadedByPhantomPilots1436902164.146251.jpg ImageUploadedByPhantomPilots1436902182.103932.jpg ImageUploadedByPhantomPilots1436902195.484639.jpg ImageUploadedByPhantomPilots1436902212.437679.jpg
  2. sherpa
    White Lake, Mi
    You're welcome!
  3. IflyinWY
    Where the deer and the antelope play
    Gotta love the happy endings. Good for you Jimmy...:) now lets see some video :D:D:D
  4. Jimfreestyle
    Coming soon :) cheers dudes!
    IflyinWY likes this.
  5. JKDSensei
    USA
    Can you tell me about your telemetry setup ? :)
    I'd like to know what hardware you used.
  6. Jimfreestyle
    Hey JK do you have an FC40 do you want the full fpv set up with telemetry?
  7. Jimfreestyle
    Yo! Please see attached what I put inside my FC40 NAZA PMU V2 and the IOSD mini which gives you the telemetry video in and output for for your fpv transmitter.. I had soldered wires from my go pro 3 to the iosd mini then a video feed out from the mini to my boscam 5.8ghz transmitter which then sends the signal down to my screen with on screen telemetry I can send you a list of what you need to purchase to do this I can also guide you on how to get it all working. I also have my camera set on a 2d gimbal which can be pitched up and down from my phantom controller whilst flying to boost the video signal feed I used clover and coil antennas which should go be you a range of a few miles not that I'm going that far lol ImageUploadedByPhantomPilots1437494840.588402.jpg
    sohail99 likes this.
  8. JKDSensei
    USA
    Right now I have a P1 v1.1.1
    I'm not really looking for FPV with this one. Just telemetry
  9. Jimfreestyle
    Do you want live telemetry?
  10. Tallyrver
    Tallahassee Fl.
    Are you using the stock FC40 radio and receiver? If your FC40 uses a 5.8 ghz transmitter and you use 5.8 ghz for your fpv, it will cause control problems.
    On my FC40 with the 5.8 radio ,I used a 2.4 ghz fpv transmitter.
  11. Jimfreestyle
    No it's 2.4ghz
  12. IflyinWY
    What are you referring to as "Telemetry"?
    Perhaps you should search, or post a thread in the P1 forum, instead of inquiring here. It just creates confusion because of the conflicting frequencies.
  13. Jimfreestyle
    Did you have any more thoughts on the other question I asked you ?
  14. IflyinWY
    I'm not sure who your question is directed to. It really helps to hit the "Reply" button when you want someone to know you are directing your post to them.
    If you are asking me, I have no idea to which question you are referring.
  15. Tallyrver
    Tallahassee Fl.
    That's good,as long as you don't use the same frequency for your fpv transmitter as the Phantom's you will be good. I saw your parts list above with the Boscam 5.8 ghz transmitter.
    I had about the same setup on my FC40, but mine had the 5.8 ghz radio ,so I had to find a 2.4 transmitter. I built a F550 and moved everything to it.
    I thought all FC40's used 5.8 ghz.
    Wayne
  16. Jimfreestyle
    Wayne. I thought the same thing hence my dilemma, I purchased the phantom a few months a go .. I purchased it new and it was sent with the fc40 camera I'm beginning to think it's a phantom 1 but for some reason they are selling it with the fc40 camera.. Obviously if this is correct the company I purchased it off should not be doing this as the controller is also 2.4ghz I could have lost signal and crashed it. I have sent them an informative email. Do you know if the p1 has the NAZA v2 in it ? As mine does cheers James
  17. Jimfreestyle
    Message above
    I'm just trying to figure out what I've purchased .. Can't send it back now as I've modded it to death lol
  18. Tallyrver
    Tallahassee Fl.
    Look on the back of your RC radio ,it tells you what the frequency is . Mine is 5.8 ghz.
    The FC40 stock camera uses 2.4 ghz for the wifi. I would think you have a 5.8 radio system.
    Wayne
  19. Jimfreestyle
    Yeah that's the problem the controller has 2.4ghz on the back of it that's why I ran in to problems when I hooked up the 2.4ghz transmitter
  20. Jimfreestyle
    Yeah that's the problem the controller has 2.4ghz on the back of it that's why I ran in to problems when I hooked up the 2.4ghz transmitter.
    I've not got a clue why the company is selling it as an fc40 and sending the fc40 camera with it?
Similar Threads - Knew Zero I'm Forum Date
I knew I should not take the challenge !! Clipped a tree ! Pro/Adv Discussion Nov 13, 2017
We knew it would happen...now it has News Sep 22, 2017
I KNEW this would happen... Rules and Regulations Jul 17, 2017
Knew it was going to happen some day... Standard May 29, 2017
It's here at last, I knew it was coming! General Discussion Apr 25, 2017
