I have 2 lots of green homelock flashes
Discussion in 'Phantom FC40 Discussion' started by leekiya, Oct 1, 2014.
  1. leekiya
    Lee. UK
    All is well with my phantom and it flys good ect ect. How ever on start up it it warms up ect and then i get my 20 or so green home lock flashes and then maybe a green and a red flash or so and then another load of green home lock flashes again. Is this normal i think it has only done this since i turned on failsafe and the ioc in the naza assistance sofware but i could be wrong with that, it might have done this all the time i cant rmbr. Is this normal.
  2. jerrymac12000
    Colorado Springs, CO
    If you flip the sw1 and sw2 switches after the satellite lock on, you will get both red and yellow lights. After you flip the switches to the upper position the lights will go back to green. That is normal.
  3. syotr
    It is normal to get two sets of rapid green flashes. The first indicates course lock has been set (compass heading) the second set indicates home lock has been set (position to return home from GPS.) Sometimes these will happen one right after the other so you may not recognize the second set of flashes. When I am not certain that the home position has been recorded, I flip s2, the left hand switch between the lower two positions several times and this will reset home position.
  4. leekiya
    Lee. UK
    Ah yes i see that makes sense, cheers and thanks very much.
  5. Jesse_M
    Woodland Park, CO
    I noticed this yesterday. Flew for the first time since enabling HL/CL and it did the fast green flash twice in a row. Tested using HL and wow that is so awesome! No more worrying when I lose sight of my bird. Messed up my first try because I switched to ATTI then HL and nothing happened. Forgot that HL works in GPS mode. Did it correctly and she flew right back home. Such an awesome feature!!!
  6. robbo11
    Kellyville, New South Wales, Australia
    Hi, I have be watching the posts and thanks for the good advice you give. I'm only a new owner and having a great time so far, just a question with this post to apply this home lock is that in Phantom mode? Which I will be using for a fair amount of time until I become more proficient. Thanks.
  7. Cajvol94
    Phantom mode???
Similar Threads - lots green homelock Forum Date
Greenville Area Pilots? Southeast USA Aug 18, 2015
Phantom Pilots near or in Bowling Green, Ky. Midwest USA Mar 13, 2014
New Hamshire Area pilots Northeast USA Sunday at 8:32 PM
Joining the PhantomPilots forum with a P4S! Introductions Sunday at 11:27 AM
50,385 Remote pilots as of August 1, 2017 News Friday at 11:25 PM
