I drawned my p2v+ but.????
Hi guys
Before two weeks my phantom v2+ drowned in river and stays in the water for 10 minutes
I tried to dry it with hair dryer and it is completely dry then i turn it on
Every thing is working perfectly but when i turn on the propellers for taking off and it takes off but, suddenly it turns upside
down and falls down.i repeat it 3 times and every time same thing happened.
And the propellers keep running until i turn them off..
any ideas ..?
Have you had it plugged in and checked IMU and compass values etc? All the basic stuff.
All your light flashes normal?
Your first mistake was thinking you could dry it with a hair dryer. You need to take apart dry it out , blow it out , then put in a bag of rice for about a week. Without trying to start it , battery too. If you turn it on its probaly screwed.
Everyday there a post about this. Put in a bag if rice and pray.
Yes i check the IMU status via firmware and all data ok
And the lights all ok
Even i calibrate it and i got 6 satellite but the problem its flip up side down
Need more suggestions if anyone has same problem
Go to Assistant ->Basic ->Aircraft and make sure 2nd box (QuadRotorX) is selected
Good call.
You could also test each motor individually as well. Spin each one up in turn using the assistant software to check that they are all running freely. Do this with the props off, naturally...
shimuafeni fredrik
