This is long but I'm trying to get all the info to anyone that can help
I'm tying to update to the 1.3.2
I have the 1.9
I KNOW the problem is ,,,I'm a computer IDIOT, but I have watched the youtubes on Downloading new FW to Mac book pro ,installing FW on SD card,updateing the FW to the P3P
I followed this you tube
Downloaded 1.3.2 Packet: P3X_FW_V01.03.0020.bin 95MB on good clean card ,installed card and the P3P went through the beeps 27 minutes later its done and I check the results
And this is what I get
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
So I erase card and start again, but now I cant get it to do the beeping
I dont know but ,(see above,,,computer idiot),,,I think the problem might be when I drag the zip to the SD card it's still a zip. whenever I try to unzip the 95.9 MB file P3X_FW_V01.03.0020.bin it makes duplicate which reads ,,P3X_FW_V01.03.0020.bin.cpgz ,, which is about 44MB . I called applecare asking how to unzip these and they said it is unzipped ,the one I want to install is The 44MB .
So I erased the card ,put the 44MB file on the card and then put card back inthe P3P but got nothing.
I just got done flying and it still flys fine
I have the 1.9
Result: Abort.
