I can't seem to take clear pictures...what am I doing wrong? See Pic, Please!
Discussion in 'Standard/4k Discussion' started by SkyviewLou, Sep 14, 2016.
  1. SkyviewLou
    I'm about 3 weeks in with my drone and I would say as a semi-professional photographer, this is one of the coolest things I've used. It's awesome. I have the 3 - 4K. While I can get great video, I can't seem to take non-blurry photos. I've attached a pic I took of the kids/cousins for Grandparent's Day on Sunday. All in all, it's not a good picture. Faces are blurry, etc. (Disregard the white faces, I played with the coloring some but had to leave to go see them and had to send the photo.)
    How can I make it better?
    Info on shot: 1/320 shutter speed, f/2.8, ISO 800
    Perhaps the answer you can't shoot a crystal clear photo on this thing above an ISO of, maybe 600?
    Any advice is appreciated.
    SkyView in the 'Lou
  2. GadgetGuy
    Is this a camera jpg or a DNG? Get closer to fill the frame with the kids.
    For best results, always shoot in DNG at the lowest ISO, and wait for the drone to stabilize before shooting, and stay under 3 meters to let the VPS assist with stabilization. Use the fastest shutter speed possible without any ND filters. Take multiple shots. Get closer and, if necessary, composite the component shots of a closeup panorama to increase resolution. Avoid any wind. The P3 is a better video camera than a still camera. Try 4K video and extract out a sharp still frame.
  3. Sinisalo
    Use 5 shot aeb to shoot the photos, if there is ghosting use the default lightroom function to combine them, if no ghosting then use the lightroom enfuse plugin. Shoot at iso 100 or 200, use the define 2 nik plugin to reduce noise, use the camera raw filter to make adjustments and the nik color efex pro 4 filter to make color corrections.
  4. Aido
    Inverleigh, Australia
    I'm no expert with the p3 yet, I have only just got mine but a rule I was taught with digital dslr is to always keep ISO setting as low as possible, it cuts out noise (grainy images).
    Cheers
    Adrian
  5. SkyviewLou
    Great, thanks Gadget Guy. One question: Can you give me some direction on how I can "composite the component shots of a closeup panorama to increase resolution"? I don't have a clue what you are saying. Thanks!
    Andy
  6. SkyviewLou
    Dear Sinisalo, thanks for the response. I appreciate it. However, can you give me a bit more detail on this: Use 5 shot aeb to shoot the photos, if there is ghosting use the default lightroom function...what is 5 shot aeb? I use lightroom but am not familiar with ghosting? Is it as simple as researching this stuff? Thanks!
  7. Sinisalo
    In the camera settings you can choose 3 or 5 shot AEB (auto exposure bracketing) basically the camera will take 3 or 5 shots at different exposures and then you can combine them in Lightroom. It is kinda like an HDR photo but you have more control over which shots to use before you combine them. The benefit of using Lightroom Enfuse plugin to combine the shots is that it uses every pixel in the final combined image and then you have more control in photoshop or Lightroom and it greatly reduces noise when you are doing night shots or shots with shadows.
    Ghosting is when an object or subject moves during the burst shot. Cars, people walking etc can all cause a ghosting effect when you combine the images. LR Enfuse cannot eliminate ghosting so that is it's weakness. I always use LR Enfuse, unless there is ghosting and then I just use the built in Lightroom HDR combine function
  8. SkyviewLou
    Great, thanks so much - I'll look into it!
  9. GOVA
    This is pretty much the quality I have been getting. I must admit while 4K camera is plenty fine for video, its photo taking quality is far below what I consider good. DNG helps some, but lack of detail and chromatic aberrations are big issues.
  10. Trinimon
    Canada
    Shoot in DNG ie RAW. Set color to D-Log with Style set to Custom -2,-2,-2. ISO800 might be a bit noisy. I like to keep it at ISO400 or less. With such a wide angle lens on the done, you can get away with 1/120".
    Then use Lightroom or other post editing app to sharpen/contrast/saturation etc.
    Don't expect DSLR quality but overall, it ain't too bad.
  11. gryphon1911 (Andrew L)
    Also, if shooting RAW, you'll need to post offices the image in some kind of software.
    Sent from my Nexus 9 using PhantomPilots mobile app
Similar Threads - can't seem clear Forum Date
Facebook Live posting to wrong account. Can't seem to change it General Discussion Aug 8, 2017
Can't Seem to Update/Repair Standard/4k Discussion Feb 11, 2017
Can't seem to get DJI GO into waypoint mode Pro/Adv Discussion Oct 27, 2015
Red light on gimbal. Can't seem to update firmware. Firmware Jun 18, 2015
rookie here.can't seem to calibrate compass. Phantom 1 Discussion Jan 11, 2015
