How to remove gimbal!
Discussion in 'Standard/4k Discussion' started by ben.gopo, Apr 3, 2016.
  1. ben.gopo
    Okay so recently I had a bit of a crash with my drone, nothing was damaged except for the vibration board above the gimbal. I ordered a spare vibration board but was wondering how to take out the old one and install the new one. Any ideas? [​IMG]
  2. Air Ontario
    U.S./ Canada
    Push the disk on the clear pin upwards on the pin shaft. That will temporarily stretch the hole in the plastic disk. After a couple of minutes, slide the plastic disk off the pointed end of pin.
    The disk will shrink back quickly and can actually be used again if you wish.
    There are 4 screws holding the old vibration plate. Be sure to note how the grey multiwire plugs are routed between the body and plate so that you can duplicate those when replacing with the new plate.
    Squirrel! likes this.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
  4. ben.gopo
    Thanks guys! I got it!
    siawai likes this.
Similar Threads - remove gimbal Forum Date
P4P Failed to remove Styrofoam Gimbal Protection. Phantom 4 Pro Discussion Jul 20, 2017
Had a flight .. forgot to remove foam gimbal pad from rear. Phantom 4 Discussion Jul 13, 2017
P3 camera and gimbal on P2 vision with gimbal removed Phantom 2 Mods May 22, 2017
Forgot to remove gimbal to Phantom 4 Phantom 4 Help Feb 10, 2017
gimbal warning remove gimbal Phantom 2 Vision Discussion Sep 18, 2016
