How to record straight thru for full flight time
Hi, i'm using the phantom professional 3. For some reason when i upload the video it keeps partitioning the files every 4gb. Does anyone know how to record straight through the flight time, and do i need to change any of the settings to do so?
thanks in advance
The SD Card is formatted as FAT32 which can't handle files beyond 4GB
thanks Sabalon; if i convert it from FAT32 to NTFS do you know if that would extend the recording time? (or is it just the way it is?)
thanks again
Hi JBett, I had the same problem Sabalon's comment is correct but it will not fix the problem formatting as NTFS.
I recommend your format it as "exFAT" (select in drop down menu) it worked for me and what it does it gets rid
of all restrictions and works well.
Cheers, JV
Reactions: gringorio
wkflysaphan4
