How to re lock a gps start point.
Discussion in 'Phantom 2 Vision Discussion' started by FlyingFox, Mar 17, 2014.
  1. FlyingFox
    Cheshire UK
    Hey,
    I want to just check my understanding of re locking a start point or moving a start point from take off.
    So you wait get your GPS and good to go, take off and that's your landing point should the failsage kick in , ie hovers 20 metres and returns home should your tx be switched off or fail etc.
    If I wanted to change that, ie I now see a place further away in a hover , and I now want to set that as the home point, do you flick the switch 2 on the left back and forwards 5-6 times and wait for green lights ?
    I just want to check that's correct
  2. Visioneer
    Louisville, Ky, USA
  3. FlyingFox
    Cheshire UK
    Cheers,
    I wanted to check as I want to set off flying and move my start point for a project and put a wide safe place to land away from where I began .
  4. OI Photography
    Clarksville, TN
    The other way to achieve that would be to power it on in the wide safe place and let it get GPS lock for home position there, then move it to the (more confined?) place you want to "begin"
  5. FlyingFox
    Cheshire UK
    Thanks, my start place is a smallish rear garden, heading towards a village with a field in the middle of the flight path which is larger and safer to return to rather than the garden. The distance means I can't start at the field as will be high using FPV and flight time/ battery time dictates.
    As most say on here ,plan and keep it safe, or it flying drones could become regulated
    :D
Similar Threads - lock gps start Forum Date
Not getting GPS lock? Just go higher! General Discussion Mar 25, 2017
3D printed F450 Frame - Wonky flight and GPS lock Phantom FC40 Discussion Jan 29, 2017
Neo Chrome skin blocked GPS and altitude sensing. Phantom 4 Discussion Jul 11, 2016
Problems with staying in GPS lock mode Pro/Adv Discussion Jun 30, 2016
App reports "No GPS lock", drone's LEDs slow flash green Phantom 2 Vision + Help May 12, 2016
