  1. aerodyn
    As I recall, my P2 V+ 3.0 had a little detent at the bottom of the travel of the left stick that, immediately after landing, caused the props to enter a "low idle" mode in which they were still spinning but not fast enough to generate any lift. This made for very safe landings, because you could plop the drone onto the ground in high winds and immediately kill the lift. You could also safely issue the "hold sticks together" command to shutdown entirely without any risk, because the props were not spinning fast enough to do anything even if you bumbled the command.
    My P4 does not seem to do this. When you land it, even if you hold the left stick down all the way, it continues to operate the props at high speed and tries to keep flying for about 3 seconds, then shuts down abruptly. This leaves it at significant risk of dynamic rollover in high winds or on uneven surfaces. There is also no safe opportunity to the use the "hold sticks together" immediate shutdown command, since if you screw up the timing at all, the props are still operating at flight speed and the drone will happily respond to your request to fly backwards and to the left while yawing to the right.
    Does anyone know why this behavior was changed, and if I am missing some safe technique for reducing the prop speed quickly upon landing (rather than holding the stick down and waiting 3 seconds)?
  2. apollopark
    As soon as mine lands it goes idle as soon as I let off the stick
    Sent from my XT1585 using Tapatalk
  3. WWK888
    Hand catch it, eliminates the possibility of damage.
    m0j0 likes this.
  4. Ron Armour
    Palm Desert, CA
    Left stick to right bottom corner and hold down the RTH button
Similar Threads - quickly kill props Forum Date
link LED flashing green red very quickly Phantom 4 Pro Discussion Jun 13, 2017
Drones is a cool thing, but when you married with kids...drone stuff die quickly and painfully... General Discussion Jun 11, 2017
Facebook Livestream always disconnects quickly Phantom 4 Pro Discussion May 14, 2017
P4P+ doesn't fly straight, loses altitude when stopping quickly - calibrated to death Phantom 4 Pro Discussion Apr 14, 2017
Gimble tilting while moving left and right quickly Standard/4k Discussion Feb 5, 2017
