How to install the PMU V2?
jpz
The PMU is arrived in a small plastic bag without any instruction, where do I find some info on how to install it?
The seller sent me the LED too, but is it useless in the phantom, right?
The PMU V2 (PMU stands for Power Management Unit) is basically a battery elimination circuit "BEC", with a Canbus communications system built into it.
The red and black wires go to battery +pos. and -neg. on the power distribution board, or ESC.
The GPS unplugs from the Naza and plugs into the port labeled GPS on the PMU.
The wires going to Naza port X-3, will be removed, and left hanging. (no longer used) The wires marked on the PMU
V-sense > X3, will plug into the X3 port on the Naza controller.
The wire coming from the PMU marked GPS, will plug into the Naza EXP port where you pulled the GPS wire from earlier.
Now you have to make sure to download the latest firmware, and software from DJI . Once you do, your Naza will be
upgraded to Naza M V2.
You can now use the Canbus system to install other DJI Goodies, such as the Zenmuse gimbal.
There are diagrams online at dji-innovations.com
Here are the installation videos for the PMU V2 and the Zenmuse H3-2D Gimbal from dronefly.com
http://www.youtube.com/watch?v=9NTrNsP4pDA
http://www.youtube.com/watch?v=aOubBs1RPcw
http://www.youtube.com/watch?v=32NKqNzJSmw
If you don't have the PMU V2 you can purchase it here https://www.dronefly.com/ProductDetails ... &Click=929
And if your on the verge of getting the Zenmuse H3-2d gimbal dronefly can answer all of your questions. They have great customer support. You can purchase the Zenmuse H3-2D Gimbal here http://www.dronefly.com/ProductDetails. ... &Click=929
You can get anything else that you need at http://www.dronefly.com/?Click=929
Thank you Audaciter and samob!
I'll do this in the next days waiting for the gimbal :)
wkflysaphan4
