How to install bluetooth module on Phantom 2
Discussion in 'General Discussion' started by VoicOfReason, Sep 7, 2014.
  1. VoicOfReason
  2. VoicOfReason
  3. Suwaneeguy
    On one leg of the landing gear you should find a canbus connector.
    Plug it directly into that.
    If you have iosd mini, plug it into the mini.
  4. ElGuano
    BTU isn't supported by Phantom 2 last I checked. There is no app that you can use access it.
    In any case the physical connection is canBus so you cannot plug it in directly to the Naza. You would have to plug it into the leg or iOsd mini (or create your own parallel bridge off some point of the bus).
Similar Threads - install bluetooth module Forum Date
How to install DJI IOSD + 2.4 G Bluetooth Ipad Groundstation Phantom 2 Help Nov 25, 2013
How to install DJI IOSD + 2.4 G Bluetooth Ipad Groundstation Phantom 2 Vision Discussion Nov 25, 2013
Itelite dbs install screw up Standard Saturday at 12:53 PM
Install Google Play Support on P4P + Controller Phantom 4 Pro Discussion Jan 9, 2018
DJI GO 4 WILL NOT INSTALL ON IPAD MINI 2 Phantom 4 Discussion Dec 24, 2017
