How to downgrade from 1.4 on my P3P
Hi guys can anyone help me here with downgrading from 1.4 back to my previous version 1.26? I'm having a problem with my my video feed. It happened around the time of my firmware upgrade. I just want to try and see if this helps
Thanks Jase
Thanks Jase
You probably shouldn't do that even if you could. There may be some unintended consequences since the app and FW has changed a couple of times.
Thanks for your reply. Problem solved it was actually the lead that runs from the gimbal to the VPS unit that had a wire that was broken. I actually contacted DJI about down grading the FW and you can do it but only to 1.3.2 and not the 1.2.6. You do it the same way as if you upgrading but with the 1.3.2 files. I did it and it worked fine
Thanks again Jase
