how to descend with litchi app
Discussion in 'General Discussion' started by Corey Tucker, Apr 6, 2016.
  1. Corey Tucker
    i want to fly a mission over a pool and descend real low over it. how can i do this with out setting a new waypoint? is there an action for that? i want to come in at 300ft and descend to like 25ft so is there now easy way to tell it to stop drop and then go back up again?
  2. Mark The Droner
    There is no way to do that without setting a new waypoint. But you can still do it. You'd make three way points. Ex: One at the pool's edge at 300 ft. One in the middle of the pool at 25 ft. One at pools edge high altitude.
    You must check the elevation of the pool relative to your home point's elevation. You're gonna need to do some math to make sure you don't screw it and end up in the water.
    And then also take into account some error. In other words, don't fly down to 25 ft the first time, try 50 ft, and then consider going lower next time.
  3. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    This pool your wanting fly over Is empty of people right ?
  4. Corey Tucker
    the ones i flew over so far have been . guess its too cold right now. but i will fly it again like you said and keep getting lower. they need to make a camera that zooms in and then it woulnd't be so hard to get good vid.
  5. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    Is what I thought you was wanting to do .
    Thanks for responding back :)
  6. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    Just keep in mind you may be violating laws or regulations by hovering close to pools you do not own or have permission to fly over. It could be seen was a privacy invasion. If your high enough and not hovering (just passing by), you should be okay.
    grottoli and dirkclod like this.
Similar Threads - descend litchi app Forum Date
Descending at .2 mps would not descend any faster Phantom 4 Pro Discussion Sep 21, 2017
Ascend or descend when you hear aircraft approach ?? Pro/Adv Discussion Apr 20, 2017
Scared. Power down to 10% would not descend from 80' Phantom 4 Discussion Apr 17, 2017
Newbie question: Can I shut down motors by descending too fast? Phantom 4 Pro Discussion Mar 3, 2017
P3S Is it normal for my phantom to wobble when descending Standard Mar 3, 2017
