How to cache maps in iOS ?
Discussion in 'Pro/Adv Discussion' started by SMD, Jan 19, 2016.
  1. SMD
    SMD
    Did a lot of searching and can't find a good thread or tutorial on how to cache the maps using an iPad 4 mini (or similar) along with a P3 Pro. Any tips?
    I watched a couple of videos using android. I like the feature of being able to draw on the maps. Is that another good way to navigate? I've used the radar to assist in flying home but using the draw feature looks like another good alternative.
  2. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    Open up the Go app and in the general settings and slide the "Cache Maps" button. Then go to the map view and view the area you will be flying in. After you have looked at all the areas you will be, close it up and head out to fly. ;)
  3. SMD
    SMD
    Thanks for your reply. What happens the next time I go out to fly? Do I have to erase the previously cached maps or can I add a new area? How long do the cached maps remain on my iPad?
  4. LuvMyTJ
    Staff Member
    Should remain cached. I use this method and I only have to do it once for any particular area.
    SMD likes this.
  5. SMD
    SMD
    Thanks!
  6. lotusteve
    sheffield uk
    so could i cache all of the uk ?.
  7. LuvMyTJ
    Staff Member
    Never tried doing large land masses but I suppose you could. :)
  8. happydays
    Warrenpoint, Ireland
    Why?
  9. snowghost
    SoCal, USA
    Do you leave Cached Maps setting permanently on?
  10. LuvMyTJ
    Staff Member
    I do, why not? It only caches what you look at.
    Skypicswa likes this.
  11. snowghost
    SoCal, USA
    True. Makes sense.
  12. Stealth Tours
    Santa Clarita, California
    There are all kinds of videos about caching google maps to the ipad Air 2 (ios devices) and I have failed. I will try the go app. method, but I don't think that helps with Autopilot. It's a real bummer when you think you've done things correct, get to a new location, map doesn't come up, blank screen is used and the next thing you realize is that course you plan turns out to be 90 deg. rotated and badness happens really quick. I've since been told by the "beta waypoint" experts, now you can save a flight by name, get to that new location and call it up....still learning.
Similar Threads - cache maps iOS Forum Date
Cache Maps on Pilot App for iOS Pro/Adv Discussion May 20, 2015
Cache maps, more than one location? Pro/Adv Discussion Oct 4, 2017
How to Cache Maps? CrystalSky Monitors Sep 12, 2017
cant cache maps anymore ?? Standard May 29, 2017
Android Maps Wont Cache Standard Apr 19, 2017
