HOW TO: balancing Vison props (using Top Flite)
Discussion in 'General Discussion' started by Quattro1, Dec 3, 2013.
  1. Quattro1
    many people wondering on how to balance vision props, here is how I did it using Top Flit magnetic balancer.
    This setup is completely without any modification at all, I have polished the magnets, but it's recomended anyway.
    this balancer generates a very low friction, and the propeller gets a 100% senter lineup(nut has a recess in the front)
    My "vision" propellers from china was completely out of balance :eek:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Topeeka
    Topeka, KS
    Thanks Quattro... When I ordered my Vision, I also ordered the Top Flite balancer, but it looked to me as if it would not work unless you could put the shaft through the propeller center... Good to see how you did this...I had not even opened the package, but it looks like I should give it a try....thanks for the tip and the procedure..
  3. Quattro1
    you are welcome..
    but the props dosen't sit very firmly on the pin, due to the hard plastic on the senterholder, but it Works. You can easily drag a sticky tape againt the senterholder to improve it's holding capablilty.
Similar Threads - balancing Vison props Forum Date
More on prop balancing and the P4P whine Phantom 4 Pro Discussion Yesterday at 7:33 PM
propeller balancing Phantom 4 Discussion Jul 1, 2017
Prop Balancing General Discussion May 3, 2017
Prop balancing...sandpaper or tape? General Discussion Apr 14, 2017
Prop Balancing Phantom 4 Pro Discussion Jan 22, 2017
