How to attach filters to P3P?
Discussion in 'Pro/Adv Discussion' started by David Dorman, Nov 17, 2015.
  1. David Dorman
    I just purchased a 4 filter kit from Neewer. The filters are threaded and I cannot see how to attach them to the P3P lens. Does the P3P come with a UV filter attached that has to be removed to install other filters?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Yes, you need to unscrew the UV filter. Do it with as little pressure as possible. Otherwise, it'll seem impossible to remove.
  3. David Dorman
    Wow, you are correct, can't budge it!
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Make sure you're turning it to the left. If it does not budge, try wrapping a rubber band around it or wrap some other kind of rubber around it so you can grip it.
  5. Pete Leare
    Windham NH
    I found it best to have the P3 upside down and wear latex gloves. It will come off easier than you think ... Extremely light grip!
  6. BobW
    Welches, Oregon
    I raped a small rubber band around the outside and it came off easy.
  7. David Dorman
    Thanks everyone, I will give it another go.
Similar Threads - attach filters P3P Forum Date
ND Filters to attach to the camera? Phantom 2 Vision + Discussion Sep 15, 2014
Has anyone had motors or prop attachments broken in DJI Multifunctional Backpack CP.PT.000381 Phantom 4 Pro Discussion Jun 3, 2017
Having trouble Reattaching PC Board to Lower Hull Standard/4k Discussion Apr 14, 2017
Looking for spherical camera to shoot 720 degree images like the sample attached. Thanks Pro/Adv Discussion Apr 13, 2017
what are these bits called and should there be 4attached Standard/4k Discussion Mar 26, 2017
