How much is to much wind to fly
Discussion in 'Phantom 2 Discussion' started by Sanababit, May 11, 2014.
  1. Sanababit
    i have been trying to go fly my phantom, but wind is at 16mph, seems that everytime i get it up in the air in gps mode, its struggling to stay level, i am afraid of flying it like this, what is a safe zone (meaning wind velocity) to fly
    Sana
  2. panhygrous pantler
    Lots is the answer. Especially in ATTI mode.
    25 gusting to 36 was easily manageable last week.
  3. Sanababit
    Wow and your phantom did not want to roll over?, mine does, especially if i make a turn, a gust of wind would pick that end up and made it look like it wants to flip over
    Sana
  4. Garysam
    Prior Lake Minnesota
    WOW.... I must be a wimp I usually put it down when it gets over 10, typically you'll have more wind at higher altitudes so I just pack it in. But I'm still pretty new so not as bold as some.
  5. Sanababit
    That makes two of us, lol
    Sana
  6. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    In theory, it should be able to handle a fair bit but I think anything over 20 is not much fun. Keep in mind the wind at 100ft will typically be stronger than the surface. The higher up you go, the more wind you'll likely encounter. Not always true but it tends to work like that.
  7. Gizmo3000
    Sherman Oaks, CA
    Well, the maximum speed (listed) for the Phantom 2 is "15m/s(Not Recommended)" (33mph)
    and Phantom 1 is listed at 10m/s (22mph).
    If you're flying in winds that potentially are greater than that,. you can potentially say bye-bye to your Phantom :eek:
    flying in wind is no fun.
    But if you need to get your flying fix, stay low and safe if you're uncertain.
  8. 4wd
    4wd
    North York Moors
    The P1 is more affected because it's lighter and a bit less powerful I guess,
    The tricky part is landing, and you need to keep even further away from any obstacles.
Similar Threads - much much wind Forum Date
Is there too much wind to fly? Phantom 4 Help Jul 20, 2017
How much wind can a P4 take General Discussion Apr 6, 2017
How much wind is too much? Pro/Adv Discussion Oct 20, 2016
Wind: How much is too much for you? Pro/Adv Discussion Jun 13, 2016
How much wind is too much? Phantom 4 Discussion Mar 16, 2016
