- Joined
- Nov 24, 2016
- Messages
- 434
- Reaction score
- 110
- Age
- 34
I have a venom duo charger and had always wanted to make my own charge cable and try to charge my phantom 3 batt with my own charger vs dji.. For obvious reasons. Only reason I didn't was cuz I afraid to try it with out knowing for sure whether it would work or not.. Well little did I know ppl were already doing this
So the other night I was on YouTube and decided to give it a search, thinking "god there's gotta be some way you can charge these Phantom batts, smart batt or not, it's still a lipo!" Sure enough I found out how, and it's as simple as I had thought it would be. Just wasn't Ballsy enough to try it until I knew for sure. But now that I know, I will be def be making and buying my own charge leads and charging through my venom duo from now on. The best part is there's no more need to buy multiple expensive dji chargers for charging more than one batt at once and I will no longer need a dji car charger since my venom charges directly from an outlet or off a vehicle 12v batt.. Both a/c and d/c current. Which is great for being out in the field..
I was just wondering how many of you do this, and how's it been working out for you? Does the charge count still see it as a "charged cycle"? And have you had any issues from charging this way..
Also what's the highest you typically will charge at? I'm thinking around 6amps Max. But the best part is when I charge at night, or when I know I won't be using the batts for awhile, I can now be able to charge at a Lower amp such as .5 or 1 or 2amps.. This is great stuff and certainly is easier on the battery's themselves! Also no more trying to manually drain your batt down to balance, or wait 2 days for the batt to do it automatically.. I'll be able to just toss it in my venom charger at "discharge" or "storage mode" the battery till its at the level in which I want it.
So stoked ! Now I can't wait to buy more battery's, Spending less on chargers!
