How long should P3S Batteries last??
I bought a P3S last spring and used it for about 30 hrs. The last time it was used was last Sept. Since then I have periodically checked the batteries and made sure they are charged. Well I rented a place at the ocean on a cliffside, and both batteries won't turn on. They come on and then after about 3-4 seconds go dead. $300 worth of batteries and they are no good? I called DJI, and there is no answer there for any help. Any help or suggestions would be appreciated
Thanks Derek
Were the lights on the battery showing a charging cycle on the charger, flashing in sequence as they charged? So when you have the charged battery in the drone are you going through the 'push the button the first time quickly and the second time push and hold' sequence?
Trying to think of simple reasons as if the batteries were in storage mode, they would have auto discharged and require a fresh cycle on both prior to use.
I have 44 charges with 92% so you should def have around 35-38% left if anything
cokersean20
