I know it's cold out but even in my house it takes about 2 1/2 minutes to get the green go ahead. I remember the first time it only took a minute or less. What are your times.
Does DJI recommend this? My new P3A takes more then 1min.Warm up can be reduced by placing the phantom in the fridge immediately prior to performing an imu calibration.
Its something I do. The tip was provided to me by a tech in an autjorised dji service centre. I suggest you make your own enquiries and proceed if you are comfortable.Does DJI recommend this? My new P3A takes more then 1min.
I've seen videos on YouTube that suggest getting having it cold. But not putting it in the freezer. I would think it that would lead to moisture build up and that doesn't mix with electronics. The video suggested to put in trunk when going to your flying location to have it stabilized with the air temp.Its something I do. The tip was provided to me by a tech in an autjorised dji service centre. I suggest you make your own enquiries and proceed if you are comfortable.
Fridge not freezer. No condensation issues for me. I dont understand the transport in trunk temp stabalisation as doing much either. If the temp imu cal was performed in was greater than ambient when you power up you will be waiting... thats my experience.I've seen videos on YouTube that suggest getting having it cold. But not putting it in the freezer. I would think it that would lead to moisture build up and that doesn't mix with electronics. The video suggested to put in trunk when going to your flying location to have it stabilized with the air temp.
